Individuelle EEG-Effekte durch Mikrowellen
Effect of low frequency modulated microwave exposure on human EEG: Individual sensitivity
Hiie Hinrikus *, Maie Bachmann, Jaanus Lass, Deniss Karai, Viiu Tuulik
Department of Biomedical Engineering, Technomedicum, Tallinn University of Technology, Tallinn, Estonia
Abstract:
http://www3.interscience.wiley.com/jour ... 1&SRETRY=0
"The aim of this study was to evaluate the effect of modulated microwave exposure on human EEG of individual subjects. The experiments were carried out on four different groups of healthy volunteers. The 450 MHz microwave radiation modulated at 7 Hz (first group, 19 subjects), 14 and 21 Hz (second group, 13 subjects), 40 and 70 Hz (third group, 15 subjects), 217 and 1000 Hz (fourth group, 19 subjects) frequencies was applied. The field power density at the scalp was 0.16 mW/cm2. The calculated spatial peak SAR averaged over 1 g was 0.303 W/kg. Ten cycles of the exposure (1 min off and 1 min on) at fixed modulation frequencies were applied. All subjects completed the experimental protocols with exposure and sham. The exposed and sham-exposed subjects were randomly assigned. A computer also randomly assigned the succession of modulation frequencies. Our results showed that microwave exposure increased the EEG energy. Relative changes in the EEG beta1 power in P3-P4 channels were selected for evaluation of individual sensitivity. The rate of subjects significantly affected is similar in all groups except for the 1000 Hz group: in first group 3 subjects (16%) at 7 Hz modulation; in second group 4 subjects (31%) at 14 Hz modulation and 3 subjects (23%) at 21 Hz modulation; in third group 3 subjects (20%) at 40 Hz and 2 subjects (13%) at 70 Hz modulation; in fourth group 3 subjects (16%) at 217 Hz and 0 subjects at 1000 Hz modulation frequency. Bioelectromagnetics, 2008 © 2008 Wiley-Liss, Inc."
Dokumentation auf
http://www.emf-portal.de/viewer.php?aid=15930&l=g
"Die Empfindlichkeit einiger Testpersonen gegenüber der Mikrowellen-Exposition ist am wahrscheinlichsten mit der Variabilität des physiologischen Zustands des Gehirns verbunden und nicht mit Hypersensibilität.
Zusammenfassend unterstützen die Ergebnisse die Hypothese, dass die Wirkung von Mikrowellen zwischen Individuen unterschiedlich ist."
Rezension in "elektrosmog-report" Mai 2008
http://www.strahlentelex.de/aktuell.htm
"Frühere Untersuchungen hatten ergeben, dass bei der Auswertung von Daten die Standardabweichung sehr groß war. Deshalb sollte hier untersucht werden, wie groß die individuellen Unterschiede einzelner freiwilliger gesunder Personen bei Einwirkung verschieden modulierter 450-MHz-Felder ist. Wie erwartet ist die individuelle Reaktion des Gehirns verschiedener Menschen sehr unterschiedlich. (H. Hinrikus et al. 2008)"
s.a.:
Effect of 7, 14 and 21 Hz modulated 450 MHz microwave radiation on human electroencephalographic rhythms
Hinrikus H, Bachmann M, Lass J, Tomson R, Tuulik V
http://www.ncbi.nlm.nih.gov/pubmed/1805 ... t=Abstract
http://www.emf-portal.de/viewer.php?sid ... =15481&l=g:
"Die Ergebnisse unterstützen die Hypothese der Autoren, dass sich die Wirkung modulierter Mikrowellen auf das EEG bei unterschiedlichen Modulations-Frequenzen unterscheidet. Die Mikrowellen-Befeldung, die mit 14 und 21 Hz moduliert wurde, erhöhte die EEG-Leistung in den Frequenzen der Alphawellen und Betawellen, wohingegen keine Erhöhung der EEG-Leistung während der Exposition mit der Modulations-Frequenz von 7 Hz gefunden wurde. Folglich kann unterstellt werden, dass die Wirkung eines externen Stimulus auf die Gehirn-Oszillation stärker ist, wenn die Frequenz des Stimulus' höher und nahe der physiologischen Frequenz der Hirn-Rhythmen ist. Die Veränderungen waren zu Beginn der Expositions-Abschnitte offensichtlicher. Es wurden für keine der Modulations-Frequenzen Veränderungen in der EEG-Leistung der Thetawellen gefunden.
Es wurden ebenfalls Unterschiede in der individuellen Empfindlichkeit gegenüber der Exposition gefunden.
Die Mechanismen der beobachteten Wirkungen pulsmodulierter Mikrowellen sind unbekannt."
