From Bioelectromagnetics Vol. 24, Issue 5, 16 June 2003 / 24:339-346, 2003. © 2003 Wiley-Liss, Inc.
Abstract
We studied the effect of an electromagnetic field from a cellular telephone on brain electrical activity, using a novel analytical method based on a nonlinear model. The electroencephalogram (EEG) from rabbits was embedded in phase space and local recurrence plots were calculated and quantified using recurrence quantitation analysis to permit statistical comparisons between filtered segments of exposed and control epochs from individual rabbits. When the rabbits were exposed to the radiation from a standard cellular telephone (800 MHz band, 600 mW maximum radiated power) under conditions that simulated normal human use, the EEG was significantly affected in nine of ten animals studied. The effect occurred beginning about 100 ms after initiation of application of the field and lasted 300 ms. In each case, the fields increased the randomness in the EEG. A control procedure ruled out the possibility that the observations were a product of the method of analysis. No differences were found between exposed and control epochs in any animal when the experiment was repeated after the rabbits had been sacrificed, indicating that absorption of radiation by the EEG electrodes could not account for the observed effect. No effect was seen when deposition of energy in the brain was minimized by repositioning the radiating antenna from the head to the chest, showing that the type of tissue that absorbed the energy determined the observed changes in the EEG. We conclude that, in normal use, the fields from a standard cellular telephone can alter brain function as a consequence of absorption of energy by the brain. Bioelectromagnetics 24:339-346, 2003. © 2003 Wiley-Liss, Inc.
http://www3.interscience.wiley.com/cgi- ... 5389/START
Nonlinear changes in brain electrical activity due to cell p
Gigaherz
Re: Nonlinear changes in brain electrical activity due to ce
Der deutsche Text dieser Nachricht kann bei www.elektrosmognews.de ( 25. Juni 03) nachgelesen werden, so dass wir uns hier die Übersetzung ersparen können. Wir danken Elekrosmognews für die schnelle Übersetzung ins Deutsche.
Gigaherz
Gigaherz
madu
Wertes Gigaherzteam
Ist die deutsche Übersetzung nicht viel eher auf www.elektrosmog.com oder www.elektrosmognews.de zu finden.
Die Seiten von www.elektrosmog.de ist lediglich das Verkaufsportal der Firma Aaronia mit ihren mich nicht überzeugenden Produkten.
Gruss madu
Gruss madu
Gigaherz
Ja klar! Das war ein Verschreiber und wir haben ihn sofort korrigiert. Es muss heissen: www.elektrosmognews.de
Vielen Dank für Ihre Aufmerksamkeit, Madu!
Gigaherz
Gigaherz
