Die Vereinigung der amerikanischen Umweltärzte haben vor wenigen Tagen einen eindringlichen Appell veröffentlicht:
American Academy of Environmental Medicine Recommendations Regarding Electromagnetic and Radiofrequency Exposure
11.07.2012
Physicians of the American Academy of Environmental Medicine recognize that patients are being adversely impacted by electromagnetic frequency (EMF) and radiofrequency (RF) fields and are becoming more electromagnetically sensitive.
The AAEM recommends that physicians consider patients’ total electromagnetic exposure in their diagnosis and treatment, as well as recognition that electromagnetic and radiofrequency field exposure may be an underlying case of a patient’s disease process.
Based on double-blinded placebo controlled research in humans [Rea WJ, Pan Y, Fenyves EJ, et al. Electromagnetic field sensitivity. Journal of Bioelectricity. 1991; 10 (1& 2): 243-256.], medical conditions and disabilities that would more than likely benefit from avoiding electromagnetic and radiofrequency exposure include, but are not limited to:
• Neurological conditions such as paresthesias, somnolence, cephalgia, dizziness, unconsciousness, depression
• Musculoskeletal effects including pain, muscle tightness, spasm, fibrillation
• Heart disease and vascular effects including arrhythmia, tachycardia, flushing, edema
• Pulmonary conditions including chest tightness, dyspnea, decreased pulmonary function
• Gastrointestinal conditions including nausea, belching
• Ocular (burning)
• Oral (pressure in ears, tooth pain)
• Dermal (itching, burning, pain)
• Autonomic nervous system dysfunction (dysautonomia). …
Submitted by: Amy L. Dean, DO and William J. Rea, MD
To read the full report, go to: http://aaemonline.org/AAEMEMFmedicalconditions.pdf
Audio Interview with AAEM President-Elect Amy Dean, MD and William Rea, MD
http://electromagnetichealth.org/electr ... -intervie/
Appell der Vereinigung der amerikanischen Umweltärzte
Schnellübersetzung
Schnellübersetzung
Ärzte der Amerikanischen Umweltmedizin-Akademie (AAEM) haben erkannt, dass Patienten durch elektromagnetische (EMF) und Hochfrequenz (HF) Felder negativ beeinflusst werden und zunehmend darauf empfindlich werden.
Die AAEM empfiehlt Ärzten, bei ihren Patienten die gesamte EMF Exposition in ihre Diagnose und Behandlung einfliessen lassen, sowie in Betracht ziehen, dass EMF Exposition dem Krankheitsprozess der Patienten zu Grunde liegen kann.
Basierend auf doppelblinder placebokontrollierter Forschung am Menschen [Rea WJ, Pan Y, Fenyves EJ, et al. Elektromagnetic field sensitivity. Journal of Bioelectricity. 1991; 10 (1 & 2):. 243-256], können mindestens die folgenden Erkrankungen und Beeinträchtigungen wahrscheinlich durch die Vermeidung von EMF Exposition beeinflusst werden:
• Neurologische Erkrankungen wie Hautempfindungen, Schläfrigkeit, Kopfschmerzen, Benommenheit, Bewusstlosigkeit, Depression
• Stütz- und Bewegungsapparat: Schmerzen, Verspannungen, Krämpfe, Kontraktionen
• Herz-Kreislauf-Erkrankungen und Auswirkungen einschliesslich Arrhythmie, Tachykardie, Rötung, Ödeme
• Erkrankungen der Lunge wie Engegefühl in der Brust, Atemnot, verminderte Lungenfunktion
• Beschwerden des Verdauungsapparats wie Übelkeit, Aufstossen
• Auge: Brennen
• HNO: Druck in den Ohren, Zahnschmerzen
• Haut: Jucken, Brennen, Schmerzen
• autonomes Nervensystem: Fehlfunktion
Eingereicht von: Amy L. Dean, DO und William J. Rea, MD
Vollständiger Bericht: http://aaemonline.org/AAEMEMFmedicalconditions.pdf
Audio-Interview mit dem gewählten AAEM-Präsident Amy Dean, MD und William Rea, MD:
http://electromagnetichealth.org/electr ... -blog/aaem
• Auge: Brennen
Handymania
The Biological Effects of Weak Electromagnetic Fields
Gute Zusammenstellung/Übersicht von A. Goldsworthy als pdf (Teil 1/ in englisch), erschienen in:
MCSA NEWS Vol./Iss.7 July 2012
http://mcs-america.org/July2012.pdf
u.a.: "Electromagnetic fields affect many but not all people" oder "Symptoms of electromagnetic intolerance: Symptoms include skin rashes, cardiac arrhythmia, headaches (sometimes severe), pain in muscles and joints, sensations of heat or cold, pins and needles, tinnitus, dizziness and nausea. A more complete list can be found at
http://www.es-uk.info/info/recognising.asp
Most if not all of these can be explained by the radiation making cells
leak."
gefunden in: http://prd34.blogspot.de/
leak."
Biologische Effekte schwacher elektromagnetischer Felder.
Biologische Effekte schwacher elektromagnetischer Felder. Probleme und Lösungen.
Von Andrew Goldsworthy
(Stand: März 2012)
Zusammenfassung
Viele der berichteten biologischen Effekte der nicht-ionisierenden elektromagnetischen Felder treten auf zu niedrigen Niveaus auf, um eine bedeutende Aufheizung zu verursachen; d. h. sie sind nicht-thermisch. Die meisten von ihnen können durch elektrische Wirkungen auf lebende Zellen und ihre Membranen erklärt werden. Die wechselnden Felder erzeugen wechselnden elektrischen Strom, der Zellen und Gewebe durchfließt und strukturell wichtige Kalzium-Ionen von den Zellenmembranen entfernt, was diese dann undicht werden lässt.
Elektromagnetisch behandeltes Wasser (wie es durch die elektronischen Wasseraufbereiter benutzt wird, um Kalkentstehung zu verhindern) hat ähnliche Effekte, was vermuten lässt, dass die [toxischen] Feldeffekte auch vom Blutstrom fortgetragen werden können. Praktisch alle nicht-thermalen Effekte der elektromagnetischen Strahlung können durch das Durchsickern der Zellenmembranen erklärt werden.
Die meisten von ihnen beziehen beim inneren Durchsickern der freien Kalzium-Ionen einen enormen elektrochemischen Gradienten [zwischen Innen- und Außenseite der Zellmembran] ein und beeinflussen die Kalzium-empfindlichen Enzymsysteme. Dieses ist der normale Mechanismus, durch den Zellen mechanische Membranschäden abfragen. Sie reagieren normalerweise, indem sie Mechanismen auslösen, die Wachstum und Reparatur anregen, einschließlich der MAP-Kinase-Kaskaden, die das Signal verstärken. [MAP - mittlerer arterieller Blutdruck]
Weiter, Link anklicken
http://www.elektrosmognews.de/news/20120523_132503.html
(Stand: März 2012)
Zusammenfassung
Handymania
Cases of neurosurgical problems on the rise
Muhammad Qasim
Friday, July 27, 2012
From Print Edition
"Rawalpindi
The number of cases with neurosurgical problems, including brain and spinal tumours, is on the rise, at least for the last one decade, putting a huge financial burden on healthcare facilities and families having patients with neurological disorders."
http://www.thenews.com.pk/Todays-News-6 ... n-the-rise
Über: http://www.facebook.com/pages/Artists-A ... 5666932809
From Print Edition
"Rawalpindi
Handymania
Cell Phone Radiation Standards Need Another Look
"Pediatricians Say Cell Phone Radiation Standards Need Another Look
Concerns persist over the health effects of radiation from cell phones, especially for kids. Now the nation's largest pediatricians group is asking the government to review emission standards"
By Bonnie Rochman, 20 July 2012
"It’s been 18 years since the U.S. government assessed the standards for cell phone radiation. That was back in 1996, long before the practice of giving your big kid a cell phone became as common as giving your little kid a bath. Both cell-phone technology and cell-phone use have changed in the interim, which is why last week the American Academy of Pediatrics (AAP) urged the Federal Communications Commission (FCC) to reconsider its radiation standards."
http://healthland.time.com/2012/07/20/p ... standards/
Handymania
Hope: Congress forces the FCC to update its regulations
Cellphone-safety advocate hopes Congress forces the FCC to update its regulations
By Cecilia Kang, Published: August 4
http://www.emfacts.com/2012/08/cellphon ... gulations/
oder
http://www.washingtonpost.com/business/ ... ory_1.html
oder
