From Agnes Ingvarsdottir
Swedish Environmental High Court Judgment: Mobile masts and aerials for 3G constitute an environment dangerous activity
Through the Environmental Court of Appeal (2005-10-12 case no: M 7485-04) it has now been determined that mobile masts and aerials for 3G constitute an environmentally dangerous activity according to the Environment chapter. Such activity will therefore have to happen in accordance with the chapter’s paragraphs and general consideration rules.
Background:
The question became topical in connection with the company Swedish UMTS-NET. Ltd appeal against an order from Miljönämnden in Landskrona about submitting information about the precise location of masts and aerials for 3G-mobiltelecommunication. According to the council’s view, aerials and masts for mobile telecommunication are covered by the environment chapter’s definition on environmentally dangerous activity. The council is then monitoring authority and can to prescribe an activity practician to submit all the information and documents that are needed for the monitoring.
The company appealed against the councils decisions to the County council for Skåne counties. The county council considered that aerials and masts for mobile telecommunication are an environmentally dangerous activity in the Environment chapter’s sense since it can not be said for certain that the electromagnetic radiation from the frequencies in question is harmless for people’s health.
The company appealed against the County council’s decisions to The Environmental Court in Växjö district. The court considered, unlike the County council there was not a question of environmentally dangerous activity in the Environment chapter sense, since the radiation from base stations for mobile telecommunication is to weak, and according to current scientific findings, cannot harm the environment. That meant that aerials and masts for mobile telecommunication were not covered by the Environment chapter and that Miljönämnden in Landskrona did not have a right to conduct monitoring on the masts with the support of the Environment chapter.
The environment board in Landskrona appealed against Miljödomstolens decisions to Environmental Court of Appeal at Svea court of appeal. Environmental Court of Appeal established that an activity can be environmentally dangerous even if it is not dangerous for the environment. it is sufficient that the activity can mean a risk for harm to the environment, in order to be considered a environmentally dangerous activity in the Environment chapter’s sense. No actual effect needs to occur. It is enough if there is a risk for effect. Although the risk for harmful health effects caused by the radiation from mobile masts is small, it must be considered to constitute a risk for impact on the environment, the court stated. The court referred to experimental surveys of experiments on animal that, show that radio frequencies or non-ionizing radiation can cause behavior changes and disturbances in body functions. Here, it is unclear which research was the court had in mind. The court referred further to a statement by Swedish Radiation Protection Authority in the script “Radiation from base stations for mobile telecommunication” (2001: 3), that accepted that threshold values are exceeded at a few meter’s distance straight in front of the aerial’s beams. Environmental Court of Appeal considered further that there exists risk because mobile masts can give course to psychic dread at nearby residential homes. Causing dread as a result of an activity is a form of lawlessness (illegality) that is covered by the environment chapter’s definition of environmentally dangerous activity.
Conclusion:
The Environmental Court of Appeal has thus laid down the law, that mobile masts and aerials for 3G are a environmentally dangerous activity according to the Environment chapter. It should be pointed out that the installation and use of mobile masts and aerials are not a condition duty activity, according to the chapter.
For such activity’s a planning permission is required, according to the planning law.
According to the current Environment chapter each town or rural area council has the responsibility for monitoring of non-condition duty peak activity. The council has a right to request the information needed in order to conduct the monitoring. It is also important to remark that the decision does not give any lead as to which protection measures etc. will be required for masts and aerials or if any such are required.
Tomas Löfgren, utredare, 08-729 72 63
http://www.ssi.se/News/newsEntire.asp?ID=188
Radiation from mobile + telepcommunications masts:
A base station for mobile telecommunication can concurrently work at several different frequency channels within its respective frequency band. For GSM-telecommunication the number of channels varies, normally between one and six, depending on how many members the station will serve. The “send-effect” is usually of the the magnitude of 10 W/channel. One telephone call uses such a frequency channel less than 1/8 of the time. Such a base station sends thus with the biggest “send-effect” when it concurrently serves eight telephone calls on each of its frequency channels. The total “send-effect” amounts to a maximumly of approximately 100 W.
Smaller base stations indoors, in sport halls, galleries and tunnels have in general low ”send-effect” and is not discussed more here.
UMTS will use two types of base stationes, one with send-effect of 20W/channel, mostly in urban areas, and 20W/channel in rural areas.
In theory 3 channels can be used, but in real life only one channels will be utilized.
As the masts/aerials mostly send their radiation beams straight forward, the effect will not be uniform in all directions. Most of the radiation is sent in a straight forward direction, while only a small amount of radiation is sent from the side lobes.
It is important to take considerations for this when calculating the radiation around the mast.
Common for all directions applies that the radio frequencies intensity subsides quickly with increased distance.
At distances further than approximately 5 m from the aerial the radiation subsides (W/m2) with the square of the distance from the actual mast/aerial. If the distance f.ex is three times further away the radiation becomes nine times weaker. Radiation power on ground level near a mast with a high placed aerial is low because the aerial has strong direction effect. Such an aerial gives gives maximum radiationon at ground level at a distance of 50-300 m from the mast. There the peak radiation there is low because of the W/m2 of the distance.
Regards.
Agnes.
www.mast-victims.org
Source:http://www.emfacts.com/weblog/?p=275
